Author: Subject: Cockpit trim
Neil P
posted on 7/4/09 at 10:13 PM Reply With Quote
Cockpit trim
I need something to put along the top chassis rail of the cockpit for SVA. What is usually used and any ideas on where to get some would be appreciated. I haven't managed to find any trim wide enough so far.
I also need a piece of perspex for my dash - about 15" X 6". I don't really want to buy a huge sheet from Wickes. Again, any ideas on suppliers of small pieces appreciated.
Neil
austin man
posted on 7/4/09 at 10:24 PM Reply With Quote
you can get small pieces from ebay or try a local sign maker
daviep
posted on 8/4/09 at 12:29 AM Reply With Quote
For trimming the chassis rails you can use 1.5" plastic waste pipe avaiable from B&Q. If you cut a split in it length ways it clips tightly over 1" square box. Cheap and cheerful.
OR
Find a piece of U shaped aluminium extrusion which is a good fit over the chassis rail, glue velcro to the inside of the channel and the top of the chassis. Trim the exterior of the extrusion with vinyl. Bit more classy.
Davie
jabbahutt
posted on 17/4/09 at 07:13 AM Reply With Quote
with Stoneleigh coming up get along there if you can as there are usually at least a couple of stalls selling alumnium extrusion.
I bought some last year, it's 25mm wide with a semi curved top profile and finished the top railes at the sides of the cockpit off a treat
tul214
posted on 17/4/09 at 07:19 AM Reply With Quote
Neil,
I have had off cuts from these guys before;
Plastic Engineering Products Ltd‎ -
A3, Citadel Trading Pk, Citadel Way, Hull, North Humberside, HU9 1TQ‎ - 01482 585222‎
1.6 Raw Super6 sold
