ceebmoj
posted on 24/2/04 at 09:03 PM |
diff
For thowes of you who are using a seera diff what ratio you had chosen and is the 4*4 lsd worth the extra.
Blake
cosworth
posted on 24/2/04 at 09:27 PM |
If you have a bike engien you would be best with a 3.62 or 3.3 diff, the 4.4 is far too low
bikerush
posted on 24/2/04 at 09:42 PM |
i think he meant 4 by 4 lsd![](/images//smilies/tongue.gif)
Jon Ison
posted on 24/2/04 at 09:56 PM |
depends on engine too, bike box's have different reduction on the final drive.
Jasper
posted on 25/2/04 at 09:58 AM |
Get yourself one of the gear calc sheets that are out there - somebody will have the link....
ChrisGamlin
posted on 25/2/04 at 11:17 AM |
www.bikepowered.com/chris/bike_ratios.xls
Right click and Save As if you dont want it to open in IE.
Dont forget to go into the "Data" sheet and change the RPM levels tho as they are all set to 11k maximum revs, which isnt correct. You can
also put in your own tyre combinations in the Data sheet as well, if the ones you have arent in the list.
Chris
[Edited on 25/2/04 by ChrisGamlin]
ceebmoj
posted on 25/2/04 at 11:56 AM |
thanks a lot
