speedyxjs
| posted on 21/5/09 at 07:50 PM |
Bar with a pin?
My pedals have a 13mm bar going through to pivot on which used to be threaded into the housing (which i am not using on the locost). Would it be ok to
cut the thread off and put a pin on either side to hold it in place?
adithorp
| posted on 21/5/09 at 08:15 PM |
Shold be OK. Lots of tin-tops are only held in with a circlip so a roll pin would be just as secure. You'll want to lock the shaft to stop it
rotating in the bracket (and wearing the holes) instead of the pedals rotating on the shaft. Ford use a flat on one end of the shaft and a D shaped
hole in one side of the bracket.
adrian
http://jpsc.org.uk/forum/
speedyxjs
| posted on 22/5/09 at 06:00 AM |
Cool, thanks
