Sij
posted on 24/6/09 at 04:45 PM |
Crossflow problem
Hi
I have a 1360 crossflow in my Locost and it has developed a rattle.
I was driving along giving it some stick in third gear, I heard a noise like something came out of the exhaust or a stone hitting the exhaust. I
didn’t take much notice as the car was ruining fine. As I slowed down the engine started spluttering and cut out. I pulled over and checked under the
bonnet and everything was fine. I tried starting it, it didnt want to start and sound very different. I tried again after a few seconds and it fired
up and ran fine apart from a slight rattle or a Tappetty sound on tickover. I drove back home and it seemed fine apart from the tappetty sound which
was loud on the over run sounds like a Ford ka. When I got it home I check the valve clearance which was all ok apart from one exhaust valve on
cylinder number 4 which was slightly out. I also check the spark plug and found that number 4 didn’t have a gap, so I gaped it and took it for a test
drive and everything was normal, Until a little while after giving it some stick in second gear the same thing happen again got it home and check the
clearance and plugs everything was fine. But it still sound tappetty. Especially on over run.
I don't think it has a rev limiter and think I may of over revved it.
What could it be? Any help or advise would be much appreciated.
[Edited on 17/7/09 by Sij]
posted on 24/6/09 at 05:24 PM |
Big end bearing has gone. They always make more noise on the over-run and if bad enough can cause the piston to clout the spark plug and close the
gap up.
Do you have an oil pressure gauge? If so what is it saying?
Sij
posted on 25/6/09 at 11:25 AM |
Shell bearings yes it could be. Is there anyway of checking them apart from droping the sump and checking them
I do have a oil pressure gauge I didnt notice what it was reading, I will check it when I get a chance.
procomp
posted on 25/6/09 at 11:52 AM |
Hi
Possibly a burnt out exhaust valve on #4. Check compression on all cylinders if it's valve related on #4 it will be down a long way compared to
the other three.
Cheers Matt
Sij
posted on 25/6/09 at 12:26 PM |
The car does run fine. The performance has'nt been affected. There is no misfire either. However it dosent sound normal I think the exhaust note
is slighly louder than normal.
Also there is'nt any smoke emitting from the exhaust.
I will check the compression.
Sij
posted on 17/7/09 at 04:06 PM |
Hi
I have replaced the big end shell bearing which were worn. But the rattle is still there on the overrun
Oil pressure is showing 60
Any ideas what it could be?
