Author: Subject: Bolting seats to chassi rails
ahunt
posted on 28/6/09 at 02:20 PM Reply With Quote
Hello,
Sorry if this has been cover before, but.... If i were to make brackets rather than welding bars to the chassi rails. would it be acceptable to drill and tap into the rails and have 4 bolts per bracket holding it on. just at the point of working with what ive got before i can buy seats
Adam
[Edited on 28/6/09 by ahunt]
Ben_Copeland
posted on 28/6/09 at 03:00 PM Reply With Quote
Yes, mine are bolted to the steel floor with spreader plates. That was fine.
Brackets should be fine. As long as they are man enough and you use suitable bolts.
Bolts and Nuts are better than taping
[Edited on 28/6/09 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
eznfrank
posted on 28/6/09 at 04:30 PM Reply With Quote
I may have misunderstood what you've said here but are you suggesting that the seats will be held in place with a bolt through a tapped thread?? ie. No nut??
ahunt
posted on 28/6/09 at 06:42 PM Reply With Quote
This maybe a little clearer. i mean drilling and tapping the actual rails so as the picture im bolting a frame to the chassi but tapping the rails out and using lock head nuts to secure the frame. And then bolting my seats to these frames...
adithorp
posted on 28/6/09 at 06:53 PM Reply With Quote
The tube wall will not be thick enough to take tapping.
adrian
http://jpsc.org.uk/forum/
stevegough
posted on 28/6/09 at 07:10 PM Reply With Quote
Rivnuts?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Triton
posted on 28/6/09 at 08:27 PM Reply With Quote
Depends on the seats and how they are mounted but 16swg tube won't take a thread unless weld a threaded boss on or use rivnuts but then most seats will require a nut to secure them anyway......Oh and I know a nut who makes them
www.tritonraceseats.com
www.hairyhedgehog.com
Chippy
posted on 28/6/09 at 10:32 PM Reply With Quote
I think that if you fix something through a tube, then SVA/IVA require that there is a welded in spacer to bridge the hollow section. Don't know if that would apply to seat mountings, but I bet that it will. Cheers Ray
Triton
posted on 28/6/09 at 10:39 PM Reply With Quote
Yes indeedly they will and should be done for your own safety and piece of mind.
ahunt
posted on 29/6/09 at 11:05 AM Reply With Quote
ok ill just weld some flat to the rails itll be easyer, cheers guys
