Author: Subject: how do I restore a ruber car seal?
smart51
posted on 8/7/09 at 12:58 PM Reply With Quote
Some of the rubber seals on my car are starting to show signs of age. What stuff can I put on them to rejuvenate them? I've just been to Halfords for something else and what met with blank stares.
Mr Whippy
posted on 8/7/09 at 01:01 PM Reply With Quote
why, did you ask for a bleeding nipple?
Back to black trim cleaner is good for rubber seals though in the past it was recommended to use chalk or talcum powder
omega0684
posted on 8/7/09 at 01:03 PM Reply With Quote
is the rubber perishing ir does it just LOOK a bit worse for where. if its perishing surely you'll need to replace the seal.
smart51
posted on 8/7/09 at 01:21 PM Reply With Quote
One seal looks a bit crazed on the surface but is sound underneath. A few of the others just look a bit tired. I'd heard there was something that would make the seals supple again and generally halt the ageing process for a while.
pewe
posted on 8/7/09 at 01:30 PM Reply With Quote
If you can find some try Amorall, an American product which protects and renovates all manner of seals etc.
HTH.
Cheers, Pewe.
posted on 8/7/09 at 01:37 PM Reply With Quote
Frosts sell some stuffs that you can paint on and other stuffs that allows you to copy original ruber(?) part by taking a mould then using the sutffs, it comes in different hardnessessesses too - but only in black.
posted on 8/7/09 at 02:05 PM Reply With Quote
yup, frost is your friend here!
posted on 8/7/09 at 02:06 PM Reply With Quote
STP "Sun of a Gun" basically is just tangerine oil
Land Locked
posted on 8/7/09 at 07:18 PM Reply With Quote
Glycerine is rumored to work well.
