Author: Subject: spark
rookie-rod
posted on 8/7/09 at 05:56 PM Reply With Quote
spark
hi i race autograss rods and my mk3 escort has had its day (zetec conversion) i am now building my mk2 gt2 scirrocco 1.8 on carb, but i need help with wiring. i happy with the basic, starter, alt wiring. but im unsure about the dizzy,coil and igntion modlue. how do i wiring it up to spark with min as possible? have looked into wiring diagrams and cant sus it, i just want to find out the min wiring for my spark. can anyone help me please with a basic diagram, only have week and half to have to get car built for next race (cant miss it as dont want to lose out on points).
thanking you ian
Land Locked
posted on 8/7/09 at 07:17 PM Reply With Quote
There should be a basic harness available for this, I know it's freely available and cheap here in SA.
Failing that I can look for the diagram (it's in a file somewhere in the garage)and post it for you.
rookie-rod
posted on 8/7/09 at 07:53 PM Reply With Quote
i cant seem to find a basic harness, all can find is to do with megasquit systems or inj. but any help at all would be great
Land Locked
posted on 8/7/09 at 08:13 PM Reply With Quote
No worries, i'll scrounge around in the morning.
Just to confirm, the module is the 7 pin job and the distributor has the three pin plug on the side?
James
posted on 8/7/09 at 10:46 PM Reply With Quote
thanking you ian
So it's a diagram for VW bits your after?
Club GTI website might be a good place to ask as peeps here tend to be more Ford oriented!
HTH,
James
rookie-rod
posted on 9/7/09 at 06:17 AM Reply With Quote
i have tryed club gti already mate and no replys. and vwvortex .
yes from memory i believe it the 7 pin and 3, l. its ascirocco mk2 gt2 1.8 on webber carb. many thanks for you help
Land Locked
posted on 9/7/09 at 03:05 PM Reply With Quote
Not my day, still waiting for the camera and the scanner wont co-operate.
What I have is the original VW current flow diagram. I'm going to try n do it without a picture, if this doesn't help I'll try n do a pic.
Ignition module:
Pin 1: 1.5mm goes to Negative side of coil (Label at coil will be - or 1)
Pin 2: 1.5mm Goes to Earth or battery negative.
Pin 3: 0.5mm Goes to Negative pin on distributor.
Pin 4: 1.5mm Goes to positive pin on distributor and to ignition positive.
Pin 5: 0.5mm Goes to Positive pin on distributor.
Pin 6: 0.5mm Goes to Middle Pin on distributor.
Pin 7: No Connection
Looking at the distributor so that the plug is between you and the distributor, the positive pin is the one on the right and the negative the one on the left.
[Edited on 9/7/09 by Land Locked]
