Author: Subject: Internal panels Alu or Polycarb
madrallysport
posted on 9/7/09 at 08:37 AM Reply With Quote
The internal panels on my car, i was going to make them as every one else does out of Alu sheet, but i can get ABS 3mm sheet, in carbon effect finish, would this be ok to use as internal panels or do i need to use alu for safety / IVA, please help as i need to let the supplier know today if i want to place an order.
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
Steve Hignett
posted on 9/7/09 at 08:39 AM Reply With Quote
You don't need to use anything at all!
Slater
posted on 9/7/09 at 09:00 AM Reply With Quote
I covered my tunnel with ali sheet. I used 6mm abs sheet for the boot cover. I find in the sun the abs expands alot and warps between the fixing screws. So my advice is to use ali sheet.
Guinness
posted on 9/7/09 at 09:10 AM Reply With Quote
I used the ABS that MK supplied. No problems with it distorting.
However I think a skin of ally, riveted and bonded to the chassis adds a degree of stiffness to the chassis.
So, if you are after ultimate lightweight, go naked.
For an bling finish carbon / carbon effect.
For increased stiffness use ally!
Simple!
Mike
madrallysport
posted on 9/7/09 at 10:06 AM Reply With Quote
Ally it is then, i want the chassis to be strong, well as strong as it can be. Cheers guys for the fast replies as always
