<<  1    2  >>
Author: Subject: Top Harness mounts
splitrivet
posted on 18/3/04 at 02:08 PM Reply With Quote
Top Harness mounts
Hey up chasps,got me a couple of 4 point harness's from stafford not too sure on the mounting points for the top harness.
Is it ok for SVA just to drill and bolt thru the top rail and maybe sleeve it or must some other mounting method be used.
Any thoughts gratefully received.
Bob
Alan_Thomas
posted on 18/3/04 at 03:07 PM Reply With Quote
Search the archive for threads on this one. Many cars fail SVA cos of this. The usual reason is that the mounting is too low to get the height in the SVA manual. I had to mount them on a Crossbar welded across the roll hoop about 3" above the top of the 'top rail'
Also the mounting needs to be strong drilling the top rail with or without sleeve would not have passed with my examiner.
Fozzie
posted on 18/3/04 at 04:05 PM Reply With Quote
Had to exact same as you Alan! Made slightly more complicated coz of the full race cage
The datum point for SVA meant that there was no other option.
ATB fozzie
splitrivet
posted on 18/3/04 at 05:17 PM Reply With Quote
Looks like I'll have to go down that route luckilly Ive still got some roll bar tube left over, unless anyone else has any other ideas.
Done a search but all threads are a bit vague
Bob
[Edited on 18/3/04 by splitrivet]
posted on 25/3/04 at 05:30 PM Reply With Quote
Apparent ( http://www.gibbs111.fsnet.co.uk/centrall.htm) this high enough for inertia reel belt but a LOT will depend on the seat.
macspeedy
posted on 25/3/04 at 05:53 PM Reply With Quote
funnily enough looked at this the other day on the mk it is 7/16 x 20 unf a very fine thread
Fifer
posted on 25/3/04 at 08:24 PM Reply With Quote
I also bought a Harness set at Safford. As above, you need the correct hight etc (I made up a simple jig as per the book drawing) and watch if you are passing belts through the seat holes if you have them, there are rules around this also as the seat comes into play if these slots redirect the belts. (My Cobra Roadsters just make it for hight above base of seat but after calling Cobra, they assure me the top of the slots is just right for SVA, and offered a letter to say so)
You must aslo ensure that the mounting is into a threaded collar in the tube / box, or, it can be right through a collar with a lock nut on the back as long as you can access the lock nut.
Well thats my take on it anyway, we'll see in a month or so when Mr SVA has his day !!
posted on 25/3/04 at 10:04 PM Reply With Quote
7/16" was always the size & standard thread for seat belts until metric really took hold.
If you can find a 70s car in the scrapyards the seat belt mountings yield very hand thick (8mm or so) spacer washers for packing up the mounting points.
craig1410
posted on 26/3/04 at 12:06 AM Reply With Quote
I'm in the same boat here and am using Cobra Roadster 7 seats with harness slots. I don't like the way the book recommends placing little pillars onto tube 'O' as this looks crap IMHO.
I like the idea of the crossbar on the rollbar but my rollbar doesn't have structural backstays (it has 38mmx16swg cater ham style backstays instead) and is made from 48mm o/d x 3mm thick black pipe. The rollbar is welded to the suspension turrets and I think it is very strong and would be fine for seatbelt mounts but I'm worried about what SVA will make of it.
My intention was to loop the harness over this extra bar and then actually mount the seatbelt end farther down behind the seatback on a 5mm thick plate with a welded 7/16 nut behind it.
Do you think that SVA would go for this or would they be worried about the harnesses being looped over the rollbar. I suppose they could argue that if the harness was removed, it could accidently be replaced without it looping over the rollbar and thus would not be at the correct height.
Anyone tried this setup?
Craig.
[Edited on 26/3/2004 by craig1410]
PioneerX
posted on 26/3/04 at 01:40 PM Reply With Quote
Question.....As I dont have the SVA book to hand, does anyone know if you must use 7/16th's or can I use a metric bolt (8.8 tensile stength of cause)
Fifer
posted on 26/3/04 at 01:43 PM Reply With Quote
The book states, the bolts must be "at least" 7/16 diameter. But they can be any suitable thread or size above that.
locoboy
posted on 26/3/04 at 02:39 PM Reply With Quote
Craig,
I had an idea of doing what you are proposing by way of mounting the end of the harness down the back of the rear bulkhead.
I was told that the harness bolt must be in shear loading and not in tension, so make sure that you mount it correctly.Other than that i cant see a problem with it
Locoboy
craig1410
posted on 26/3/04 at 09:20 PM Reply With Quote
Col,
Yes i was aware of the shear versus tension requirement but thanks anyway. I'm going to get bolted harnesses rather than the ones with the eyebolts because I'm not sure how SVA friendly the eye bolt type are. The shear requirement is just that the tension on the harness should be pulling the mounting bolt at 90 degrees to the axis of the bolt rather than trying to pull the bolt out of the hole directly. This should ensure that the mounting will tear long before the bolt itself pulls out of the threaded hole.
Do you think I'll need to wrap the rollbar in plastic or something to avoid the metal to harness contact? Of course I will make the rollbar very very smooth and remove any sign of a sharp edge.
Craig.
craig1410
posted on 26/3/04 at 09:21 PM Reply With Quote
PioneerX,
I think you would have to move up to an M12 8.8 grade bolt but I don't see a problem. I went with 7/16 UNF because it has always been the standard for seat belts and should be compatible with most eye bolts and other fixings.
Craig.
Fifer
posted on 26/3/04 at 10:41 PM Reply With Quote
FYI
The SVA sixth ammendment (received today ) has pictures now of whats acceptable, and whats not. pretty informative actually compared to previous manual.
posted on 26/3/04 at 10:52 PM Reply With Quote
I used M12 8.8 to mount my 3 point harness and it passed. It uses the welded on roll bar cross brace as anchorage and was fitted through a threaded plate welded to the underside of the bar and taken back and then over the brace to take up a bit of extra length. The other ends are bolted to the floor behind the seat with a large washer on the underside of each bolt.
craig1410
posted on 26/3/04 at 11:54 PM Reply With Quote
Fifer,
That's good news about the new SVA manual, I have been wanting one for a while but didn't want to get the old version. I actually sent a cheque away a while back but it was returned as the price had changed from £30 to £35. Can you confirm that it is still £35 so that I can send away my order form again?
Craig.
Fifer
posted on 27/3/04 at 10:29 PM Reply With Quote
I think it is 35 quid. I was only getting my update for 17 quid so I would check the new full book price just in case.
By the way, on the upper mounting discussion, the new ammendement has little sketches of the threaded bush through the roll bar set up and one of the acceptable ways shows a threaded bush, welded onto the roll bar tube along its side ! i.e. the bush is parrallel to the tube it's welded to.
Seems strange they say this is acceptable but they show a picture of a bush welded to the tube at right anges (but not penetrating the tube) and this is shown as unacceptable !!
Best way is to do as stated above, insert bush thru tube, weld either side, and bolt seat belt mount with correct bolt all the way through.
Ah well, thems the ones that make the rules, we just have to develope the skills of a Philydelphia Lawer to work them out
Is that how yopu spell FILIDELFIAA
highspeeddirt
posted on 27/3/04 at 11:27 PM Reply With Quote
If the new manual is the same as the draft sixth manual available online then I think they mean you can weld the sides of the bush onto a chassis tube in an upright position but not 'end on' on top of the tube. The text seems to make more sense to me than the pictures.
Fifer
posted on 29/3/04 at 09:27 AM Reply With Quote
Thats correct.
My limited understanding of weld stresses etc tell me that welding a bush in this way is much the same as welding a bush at 90 deg to a tube, i.e. the forces are trying to rip the bush from one side of the tube steel, why one is acceptable and the other isnt, is a mystery to me.
My own car has the bush welded right through the x bar and threaded so hopefully it will pass
blueshift
posted on 29/3/04 at 01:30 PM Reply With Quote
Craig, I would guess you might have problems looping your harness over a tube, even if it looks quite smooth they might fail it on the grounds it would chafe and eventually wear out. This is just my random paranoia though, I don't actually know.
posted on 29/3/04 at 03:15 PM Reply With Quote
This is how I did it.
The plate is welded to the underside and the roll bar is welded to the chassis Rescued attachment beltrear.jpg
posted on 29/3/04 at 03:19 PM Reply With Quote
The plate is 5mm thick and the bolts are M12x40mm and go inside the roll bar which was tapped at the same time as the plate. Rescued attachment beltfast.jpg
posted on 1/4/04 at 07:36 AM Reply With Quote
The bolts aren't loaded in shear in fact the seat belt eye plate will act like a crowbar and try and rip the mounting boss out of it welds..
posted on 1/4/04 at 09:16 AM Reply With Quote
It passed SVA. If that's not shear what is? The bolt is at right angle to the belt and the seat belt would have to shear the head off to break loose. 12mm, it's never gonna happen. Your idea of shear and other people's probably don't coincide, I'll go with someone who matters.
<<  1    2  >>
