type 9 output
the diff from my donor uses a prop with bolt on cv joints, same as a cossie rear diff with the 108mm lobo shafts.
i was wondering if possible to source a output for type 9 that has a flange on it for one these joints?
or what other cars use same size of output as the type 9 but have a uj on them rather sierras rubber donut, so i can make up a shaft with a uj one end
and cv other, im not worried about speed fluctuations of one uj as wont be that much off line but im worried it will be too off line for a rubber
donut to take
thanks stephen
