eddie99
| posted on 13/10/09 at 07:12 PM |
Dashboard Regulations
Hi Guys,
Im actually re doing my dashboard/centre console panel properly for my alevel project, and we have to do lots of portfolio research and regulations
etc...
Just after a list of the IVA Regulations for dashboards.
Also providing the dashboard is radiused, does it matter how "hard" it is, im planning on using mdf and using formica as a surface but i
know its "hard".
Thanks in advance
Ed
Confused but excited.
| posted on 13/10/09 at 07:20 PM |
Go To:
http://www.transportoffice.gov.uk/crt/repository/IVA%20Inspection%20Manual%20for%20M1%20Passenger%20Cars%20July%2009.pdf
and download, then read the relevant section.
matt_claydon
| posted on 13/10/09 at 07:21 PM |
If this is supposed to be your research, I suggest you read the manual!
Macbeast
| posted on 14/10/09 at 07:08 AM |
The instrument panel lower edge within the “specified zone” must have a radius of curvature not less than 19mm or 5mm and covered with a non-rigid
material.
Note 6: A "non-rigid material" is a material which has a hardness of less than 50 shore A. For the purposes of this examination it will be
deemed to be a material which is capable of depression under thumb pressure and when deformed retains a degree of protection against contact with any
structure which it is covering and when released returns to its original form.
