speedyxjs
posted on 23/10/09 at 10:29 AM |
How to 'disable' button
Reading rgrs's post in this thread (p2), i was wondering how to
disable the button so it might magically, re-able itself post IVA?
Jasongray5
| posted on 23/10/09 at 10:36 AM |
Make an ali cube, just so that it fits over, use a weak glue, so you can pull it off post test?
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
blakep82
| posted on 23/10/09 at 11:21 AM |
can you mount it behind the dash so the buttons are covered?
________________________
speedyxjs
| posted on 23/10/09 at 12:40 PM |
No. Iv already made the dash and dont really want to make another one. I like the ali cube though. Would it be seen as perminant?
Jasongray5
| posted on 23/10/09 at 12:47 PM |
well, I suppose that would depend on the glue you used. And its sort of 50/50 wether the tester will give it a tug...?
How hard can it be?
| posted on 23/10/09 at 01:39 PM |
Can you get inside the casing? If so, you might be able to slip a bit of thin plastic into the switch to deactivate it temporarily - the tester can
push it as much as he likes but nothing would happen.
Alternatively, can you make something that fits behind the unit (ali or stainless sheet) that curves under the base and stops the button being pushed?
If you put a bit of effort into it you can make it look 'permanent'.
nitram38
| posted on 23/10/09 at 02:09 PM |
I had the same issue with my veypor VR2. I made an ali plate so it covered the buttons and some vinyl covering it.
Can't have been fixed properly because it and the steering pad it was sunk into came off very quickly after sva. Pretty strange realy
| posted on 23/10/09 at 02:43 PM |
In the past I've disabled similar buttons (like the ones on telephones) by slipping thin bits of plastic between the buttons and the contacts on
the PCB behind them. Works for the type of button where the back of the rubber / plastic bit has a bridging contact on and the PCB bit is just two
metal contacts... Would mean opening up the speedo but hey...
Russell
posted on 23/10/09 at 03:05 PM |
From the title of this thread I thought you were proposing to nobble the F1 World Champion
I'm a bilingual illiterate. I can't read in two languages.
rgrs
| posted on 23/10/09 at 04:51 PM |
Unfortunately the design of the button prevents you from physically placing something in the switch path.
The rubber buttons cover a long shaft switch.
On mine i opened the unit and cut the track on the pcb to disable the button for my re-test.
Somehow shortly after sva a small blob of solder fell into the unit and re-joined the track..
However this would ovbiously invalidate any warantee.
hth Roger
[Edited on 23/10/09 by rgrs]
