Daddylonglegs
| posted on 20/11/09 at 07:01 PM |
Cobra Roadster 7 Seats
Not sure if I've already asked this in a previous life, but can anyone tell me if the seats I have (below) will pass the BIVA?
I have read the manual, but am not 100% sure how the measurement is taken using the block defined there.
Cheers all.
JB
AdrianH
| posted on 20/11/09 at 07:30 PM |
Is this the block 53 mm high by 136 mm wide by what ever long?
Basically get a metre rule and a 90 degree square. Measure a point 136 mm away from the back of the seat. Put the 0 mm at that point measure up 753
mm and put your 90 degree square there. Angle the ruler to be parallel with the back rest and if the line from the square at 753 mm is into the
headrest you should be OK.
Clear as mud I know!
Adrian
[Edited on 20-11-09 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
Daddylonglegs
| posted on 20/11/09 at 08:53 PM |
Thanks for that Adrian
I am in Jordan at the moment working, back next weekend so I'll see if I'm going to have to install extra headrests or not
JB
