Miks15
| posted on 15/12/09 at 06:03 PM |
interior panels, bonded?
i posted about riveting my interior panels in yesterday, but can they just be bonded in? i thought because its going to be hard to drill all the holes
in the chassis tubes, especially down by the floor. So bonding wold be so much quicker and easier.
Mikkel
turbodisplay
| posted on 15/12/09 at 06:14 PM |
I used rivets on mine, i have a few pannels. If you do want to use bonding, use a few rivets.
It is stong, but if it peels it is weaker. A rivet will halt a peel.
Darren
[Edited on 15/12/09 by turbodisplay]
sebastiaan
| posted on 15/12/09 at 06:15 PM |
I used trusty old sikaflex 4,5 years ago for the tunnel sides. Still solid as a rock. Go for it!
Miks15
| posted on 15/12/09 at 06:22 PM |
brilliant cheers, Guess i could pop a few rivets in the corners say, just to hold it all tight, just dont fancy drill hundreds of holes thats all!
Plus i would probably sikaflex it anyway to seal it.
Cheers Guys
bodger
| posted on 15/12/09 at 06:24 PM |
I think I'm going to sikaflex the sides & maybe velcro the top on. I sure that's what MK said they do now.
turbodisplay
| posted on 15/12/09 at 06:33 PM |
Dont forget it is not fuel resistant - guess how I know that!
Darren
blakep82
| posted on 15/12/09 at 06:56 PM |
sikaflex and rivet every 3" or so?
they'd be close enough to look good, but not overkill. you could always add more between later if you wanted
________________________
Miks15
| posted on 15/12/09 at 07:03 PM |
its still a bit too much work for the rivets, im trying to avoid having to drill, will be a right pain getting a clean hole in to the chassis rails
down by the floor.
sebastiaan
| posted on 15/12/09 at 08:18 PM |
Almost forgot, the rear bulkhead on mine is bonded in too!
jabbahutt
| posted on 16/12/09 at 08:02 AM |
if it's any help I used rivnuts to secure my interior panels. I too didn't fancy drilling the bottom rails so made removeable floor
panels with hard wearing vinyl which when in place keep all the interior panel bottom edges pressed against the chassis rails.
