New Topic New Reply
Author: Subject: Diff Angle on 'R' chassis
bodger
posted on 27/1/10 at 07:18 PM Reply With Quote
I've just noticed that the diff flange on my Indy 'R' is angled downwards about 3 deg from vertical towards the chassis floor. It's just a standard Sierra 3.38 diff. Has any one else got this issue with the 'R' chassis ? I would have thought it should be at 90 deg to the floor and similarly at the engine end. I know about keeping the ends parallel etc but I'm interested to know if this is a 'feature' of the 'R' chassis or whether mine is unusual. The only way I can see to fix it is to weld in a new diff bracket
James
posted on 27/1/10 at 07:34 PM Reply With Quote
Or maybe oval the holes slightly!
Breaker
posted on 27/1/10 at 08:00 PM Reply With Quote
According to http://www.baileymorris.co.uk/technical5.asp 3deg is acceptable.
I also have the R chassis, but no diff yet so I can't compare....
gordon h
it will be fine leave as it is.
bec is best but going to try sabb 2.3 turbo mk
bodger
posted on 27/1/10 at 08:33 PM Reply With Quote
ok thanks, I'll stop worrying!
procomp
posted on 27/1/10 at 08:42 PM Reply With Quote
Hi
You want the flanges etc to be parralel to each other but offset by upto 3 degre. Not angled away from each other by any angle. !!!
Cheers matt
posted on 27/1/10 at 08:57 PM Reply With Quote
If you are certain the flange on your diff is angled downwards 3 degrees from vertical, contact MK Sportscars and discuss it with them.
Phil
40inches
posted on 31/1/10 at 09:32 PM Reply With Quote
Mine goes tuther way!
New Topic New Reply
