magic55
| posted on 1/5/04 at 11:54 PM |
fuel tank
im not sure which forum this should be in, so I apologise if it should have been in engines or something. Anyways.
Im afraid im not building a locost yet, but am planning a custom fuel tank for my road car. I was wondering how (if you do) you hook up a fuel gauge
to a custom made fuel tank in a locost?
Many thanks
colibriman
| posted on 2/5/04 at 11:14 AM |
you can buy a fuel sender - i got mine from www.lowtension.co.uk
it might be universal but im not sure - i bought a set of vdo gauges at the same time
cheers
colin
Mark Allanson
| posted on 2/5/04 at 07:23 PM |
You can use the original sender form the old tank, just have to cut a hole the same as the original
James
| posted on 6/5/04 at 12:02 PM |
Mark,
Is that just a matching hole cut into the tank? (It looks like it is) Or did you weld the Sierra 'hole' onto the tank?
I cut from the Sierra tank the 'hole' from which the Sender came- but I've not been sure how best to attach this to the tank!
James
Mark Allanson
| posted on 6/5/04 at 07:14 PM |
I too cut the hole out of the tank, but just to use it as a template, I chain drilled and then filed it out, it took ages to get just right. I
didn't weld it in because the sierra tank is very thin and I wanted more strength at the cost of weight
