Sij
posted on 18/4/10 at 06:16 AM |
Burning Oil
After adjusting the valve clearance on my xflow It has started burning Oil. I removed the spark plugs, and found the plugs on cylinder 3 & 4 were
covered with oil. The valve clearance were quite tight I reset them to manu spec. could it be burnt valves?
theconrodkid
posted on 18/4/10 at 10:03 AM |
cant see that causing the problem,when does it smoke?
who cares who wins
pass the pork pies
posted on 18/4/10 at 10:35 AM |
Piston/ piston ring problem or valve guide problem.
Because of the top heavy piston design Xflo's tend to suffer more than most from bore wear if revved to any great extent.
