Author: Subject: Offset of wheels on Luego Viento
stuiesav
posted on 24/4/10 at 03:49 PM Reply With Quote
Does anyone out there have the correct offset details for both the front and rear wheels on a luego viento along with the best tyre sizing (am aware its 205 at the front!).
Any help much appreciated.
thanks
Stuart.
Snuggs
posted on 24/4/10 at 04:21 PM Reply With Quote
I am using these on my Viento
Front = Compomotive MO 5 spoke 7 x17 Offset +38 fitted with 205/40/ZR17 Yokohama AVS-Sport
Rear = Compomotive MO 5 spoke 8 x17 Offset +22 fitted with 235/40/ZR17 Yokohama AVS-Sport
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
Paul (Notts)
posted on 24/4/10 at 05:26 PM Reply With Quote
see the following link and the link within it.
I have also fitted 20mm hubcentric spacers on rear wheels to move them out to fill the arches AND to create more clearance between the wheel and sring on shocks.
Paul
http://www.locostbuilders.co.uk/viewthread.php?tid=36615
hector
posted on 24/4/10 at 08:35 PM Reply With Quote
I have the standard sierra offset on fronts and Zero offset on rears with 19mm spacers which bring the rims right to the outer edge of wheelarches!
wilkingj
posted on 24/4/10 at 09:26 PM Reply With Quote
I have Team Dynamic Pro-Race 2 rims.
ET+38 on the front (Std Ford Sierra offset)
with 7x17 wheels 205mm tyres
Rears are 8x17 with ET+22mm (the min offset they would do on 8" rims) 235mm tyres
Plus 15mm Hubcentric spacers to move them outwards a tad.
Best to use Hubcentric spacers, as they have the indent and the flange to locate on the hub and in the wheel. Especially on the rear wher you are applying the power to the road. ie done use just the flat plain spacers. Its worth the added expense.
If I was doing it all again, I would probably go with 9" on the rear and 265 tyres. (would need to check the figures again if I did that)
Best Regards
Geoff
http://www.v8viento.co.uk
NeilP
posted on 24/4/10 at 09:41 PM Reply With Quote
As Geoff but with the 9" rears (ET+22) running 255s and 25mm spacers - 5mm in from outer edge of rear arches
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
bj928
posted on 25/4/10 at 06:22 AM Reply With Quote
i think my 10" rears are +25 and the fronts are 9" with i think +22 or it could be +25 as well
