Author: Subject: Aeroscreen thichness and material
Avoneer
posted on 22/5/04 at 07:46 AM Reply With Quote
What's the best thing to use for an aeroscreen for my Avon and what thickness should it be and where can I get it????
Bearing in mind that it can only be fixed to the pillars at each side due to the scuttle being flat on top.
I was originally going to use some white UPVC and spray it black, but don't know whether it will pass SVA?
Does anyone now the maximum height you can have it before SVA class it as a screen?
Pat...
locodude
posted on 22/5/04 at 08:10 AM Reply With Quote
Hi
You can use what you like. Most people use acrylic (perspex) although it cracks and shatters under hard impact. Polycarbonate is much better although much dearer. As for the height, it all depends on the height of the seat squab. Surely you have an sva manual, it tells you in there, or sva the car and then fit it after - perfectly legal.
posted on 22/5/04 at 09:31 AM Reply With Quote
The aeroscreens as supplied by Mac1 are 6.35mm (1/4" thick. Easily cut using a perspex cutting designed blade in a jigsaw. Drill very carefully though! As Loco' says it does crack 'star' pretty easily.
HTH
[Edited on 24-5-04 by Hellfire]
Lightning
posted on 22/5/04 at 12:09 PM Reply With Quote
5mm thick perspex, radiused. Vertical supports shaped from ali sheet with extra thickness above scuttle to get necessary radius.
Perspex glued with black sealant. Quite ridged.
givemethebighammer
posted on 24/5/04 at 06:43 PM Reply With Quote
I have the template for the screen lightning has, if you want it. Or ring Tiger and ask Sue to draw round one for you, she did it for me !!!
Cita
posted on 24/5/04 at 07:32 PM Reply With Quote
You dont have to be carefully at all with 6,35 meter thick perspex,you only need a looooooooooong drill
posted on 24/5/04 at 08:03 PM Reply With Quote
I think you read it wrong...
Cita
posted on 24/5/04 at 08:07 PM Reply With Quote
That was a speedy correctionhere on the continent whe are not very familiar with the decimal system
Cita
posted on 24/5/04 at 08:31 PM Reply With Quote
Hellfire you have a U2U
