smart51
| posted on 1/7/10 at 03:13 PM |
thin foam padding on GRP seats
I've seen thin foam padding on GRP seats. What kind of foam is this and where can I get some?
daviep
| posted on 1/7/10 at 03:19 PM |
Exercise mat - Argos
StevieB
| posted on 1/7/10 at 03:55 PM |
I used 3mm stuff that I got from an auto jumble, but you can get it from Woolies
Link
It rovided a very slight amount of padding, but was mainly useful for stopping you sliding down the seat under braking (something the SVA guy was very
impressed with, eventhough it's real reason fir being there was to cover up a nasty scrape on the drivers seat from dropping a tool on it)
norfolkluego
| posted on 1/7/10 at 05:03 PM |
Just put on a bit of weight, it will go straight to your bottom.
Job done and Locost.
Of course you will have to lighten the car by the same amount
mad4x4
| posted on 1/7/10 at 05:46 PM |
Camping Mat (Carry Mat)
Scot's do it better in Kilts.
dhutch
| posted on 1/7/10 at 09:32 PM |
Ive put a layer 4mm high density neoprene on my seat, bought in sheets from a member on here. I would like to be able to take it all off again and do
a run without once more to compair, but its certainly not made it any worse and is worth it for the grip. Which if nothing else reduces the tendency
to slouch which very much does hurt after a while.
I think im going to get some 1inch open cell foam to go to nurburg on tho.
Daniel
