Daddylonglegs
| posted on 21/7/10 at 05:35 AM |
Seat Belt Mounts
I see that in most threads regarding seat belt mounts, 7/16" UNF is always quoted. Is there any reason for not using M12 bolts for the mounts?
(IVA or otherwise).
The reason I ask is because I am looking for threaded inserts for my upper harness mounts (I am putting them through the roll bar cross member) and
the only ones I've seen so far are 7/16" UNF but they are only 1" long, the tube I am using for the cross memebr is approx 40mm
O/D.
Any input thankfully received.
JB
blakep82
| posted on 21/7/10 at 07:00 AM |
IVA says 7/12" unf or equivalent strength, so anything stronger is fine.
have a look at the manual and specs for cap head bolts for comparisons. going by that, and as long as the IVA man knows his stuff, smaller diameter
cap head bolts will be up to the job
________________________
Bluemoon
| posted on 21/7/10 at 03:56 PM |
But they will also need to fit the harness...
rallyingden
| posted on 21/7/10 at 04:30 PM |
Flak Monkey made a set 70mm long for me. Mine were stainless. Good quality and reasanoably priced.
Give him a shout.
RD
Mark Allanson
| posted on 21/7/10 at 04:33 PM |
I seem to remember that the old SVA was as previously stated, but a minimum of 11mm diameter
wicket
| posted on 24/7/10 at 09:13 PM |
11mm is approx 7/16"
