davrus1975
| posted on 30/8/10 at 08:21 PM |
Rear boot
Hi all
I was planing on fitting a boot section in the back of my locost.
The only concern i have is that it will cover the underside of my seat mounts.
Do you think it will be a problem on i.v.a as i am planing on moulding it around my fuel tank etc and cant do it once build is compleate.
Many thanks
| posted on 30/8/10 at 08:32 PM |
Take lots of photos around the area that you'll be covering with the boot and present them to the tester at IVA. Should hopefully keep him/her
happy.
Phil
| posted on 30/8/10 at 08:34 PM |
Don't forget that the inspector will have the car up on a platform and will be able to see quite a bit from underneath.
But photos are a good backup...
mistergrumpy
| posted on 30/8/10 at 10:56 PM |
Just to throw a spanner in the works maybe. When I took mine for SVA at Manchester I was asked to fully unscrew and remove my boot cover until I
pointed out the big lockable access panel on top.
I suspect it will differ from station to station.
