eddie99
posted on 11/9/10 at 01:27 PM |
Resin Seat infill, PU Foam
Hi Guys
Looking at doing this in the global race car. It has a large kart seat in it at the mo which is too big and i was thinking of doing this type of resin
seat infill which is removable so others can also drive the car just removing the infill..
Has anyone else tried/done this?
Is it easy? Where is good to get the bits? I see Demon tweaks do a little kit, also found websites like:
http://www.msar-safety.com/detail.asp?p=200
http://cgi.ebay.co.uk/Formula-Ford-Racing-Seat-Foam,-Expanding-Polyurethane_W0QQitemZ330470233317QQcmdZViewItem?rvr_id=138089689003&rvr_id=1380896
89003&cguid=c1d837871290a0aad454fa34ffa0168f#ht_500wt_1115
Ed
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
flibble
posted on 11/9/10 at 01:48 PM |
Can't help on the will it work/have you tried it before front but looking at the Ebay 2 Part foam it does look very much like
>This stuff<, just more expensive
Edit: P.S. - Are you still selling wiring loom kits, have you a pricelist etc.?
[Edited on 11-9-10 by flibble]
designer
posted on 11/9/10 at 05:49 PM |
Any fibreglass stockist stocks 2-part foam.
Chippy
posted on 11/9/10 at 10:22 PM |
We used this process on the F1 cars, as they had no seat at all. What we did was pour two part foam into a black plastic bag, spread it over the
seating area and get the driver to sit in it till it had hardened, (wear thick trousers as it does get a bit warm). Then strip of the plastic sack,
clean up the resulting foam pad, them just apply a layer of GRP and the lightest weave cloth we could get. Makes a perfect figure hugging seat, fairly
cheaply. HTH Ray
