-matt
posted on 5/11/10 at 10:16 PM |
2008 R1 fuel pump
Ive just fitted a R1 pump into the bottom of my fuel tank and have noticed there are 2 nozzles.
Obviously 1 goes to the fuel rail, but where does the other go to?
Here is a pic:
cheers
PAUL FISHER
posted on 5/11/10 at 10:23 PM |
Fuel return, from the fuel rail.
omega0684
posted on 5/11/10 at 10:27 PM |
^^^^^ Correct!
-matt
posted on 5/11/10 at 10:51 PM |
Ah ok i assumed that went into the top of the tank.
Is the Return the right angled one or the straight one?
yorkshire-engines
posted on 6/11/10 at 04:20 PM |
Hi firstly that pump is not for a 08 r1 thats for a 03 to 06 as this model has a fuel return from the rail
the 08 dosnt have a return that pump will not work on a 08 r1 as there is no regulator in the pump
do not try and start engine with that pump you will blow a fuel pipe or a injector
also all r1 feed pipes are angled
cheers Malc
[Edited on 6/11/10 by yorkshire-engines]
-matt
posted on 6/11/10 at 11:51 PM |
Ah cheers.
Just had a look at the pic on the ebay listing and there is only 1 nozzle so they have obviously sent me the wrong one.
Also if there is no return what is the second fuel connection for on the fuel rail?
yorkshire-engines
posted on 10/11/10 at 12:05 PM |
The 08 r1 only has 1 fuel connector on the rail
send me a piccy and ill see if you have correct fuel injectors
cheers Malc
-matt
posted on 10/11/10 at 04:05 PM |
here are some pics:
the main one on the rail:
and this one:
cheers
yorkshire-engines
posted on 10/11/10 at 05:00 PM |
Hi first piccy (ali pipe) is fuel feed to rail
second piccy (plastic pipe) is emmissions intake blank it off
Cheers Malc
-matt
posted on 10/11/10 at 06:11 PM |
cheers malc, that makes sense.
