Dave Bailey
| posted on 8/11/10 at 09:50 PM |
Interior Side Panels.
O.k. so I have pretty much finished the inside of the car... all I need to do now is panel the inside of the outside of the chassis if that makes
sense.. Is ABS the most common material to use for this... I have used pinseal on the underide of the dash to box it in but it seems to mark very
easily.... Any other suggestions with Links?
thanks
Dave B....
rb968
| posted on 8/11/10 at 11:45 PM |
I had plenty of 1.2 mm aluminium left over so made mine and covered in black vinyl .
This is the back panel but the interior sides and tunnel sides are the same.
Finishes it off nicely.
Rich
James
| posted on 9/11/10 at 11:00 AM |
I did black vinyl onto 1.2mm ali as well.
Looked good (although not that easy to keep clean!) but the problem I had was that the summer heat killed the glue and the vinyl peeled away. I think
it'd have worked better if I'd have 'keyed' the aluminium to get better adhesion but other builders have been fine with other
different glues.
James
- Muhammad Ali
Dave Bailey
| posted on 10/11/10 at 10:36 PM |
Thanks guys.....
