daniel mason
| posted on 17/11/10 at 10:11 PM |
lower harness mounts?
how have you guys mounted the threaded eye bolts for the lower harness mounts? i have the trs harnesses with clip on mounting buckles but i dont fancy
just bolting the eye bolts to the to the ali floor!
austin man
| posted on 17/11/10 at 10:15 PM |
threaded bush welded to the chasis, I have seen people recommend photoghraphing the way the mounts are fitted for IVA purposed. These have to be
substantial mounts as the forces applied upon impact are massive
[Edited on 17/11/10 by austin man]
adithorp
| posted on 17/11/10 at 10:47 PM |
Does the MNR chassis not have lower belt mounts welded into the chassis?
http://jpsc.org.uk/forum/
daniel mason
| posted on 17/11/10 at 10:52 PM |
No lower mounting points on the Mnr chassis
steve m
| posted on 17/11/10 at 11:09 PM |
Sorry to hijack, but can lower anti dive belts be bought ???
if so were, as i may need a couple !!
Regards
adithorp
| posted on 17/11/10 at 11:32 PM |
That does surprise me.
Have a look at the IVA manual. The old SVA one had quite detailed description and drawings of what was and wasn't allowed with belt mounts.
Johneturbo
| posted on 18/11/10 at 12:29 AM |
Are you sure? mine has two plates for lower harnesses built into the chassis
Johneturbo
| posted on 18/11/10 at 12:43 AM |
Here you go
blakep82
| posted on 18/11/10 at 05:32 AM |
quote: Originally posted by Johneturbo
Here you go
isn't that still 2 plates short though?
________________________
adithorp
| posted on 18/11/10 at 09:38 AM |
Here you go
Well the drivers side outer one isn't in the picture and the passenger inner is obscured by the tunnel I'd presume.
Johneturbo
| posted on 18/11/10 at 01:57 PM |
Ditto with what Adrian said
daniel mason
| posted on 18/11/10 at 04:50 PM |
it has those small steel plates welded in but they are only very thin (2-3 mm) and i dont want to use them as my only protection. any other options?
Johneturbo
| posted on 18/11/10 at 05:00 PM |
what you need to do is when you buy your harneses also buy these to sit under
will be fine unless you weigh 50stone!?
the steel plates are for the harnesses
you think about how much force you'd require to brake them.. sheesh
[Edited on 18/11/10 by Johneturbo]
daniel mason
| posted on 18/11/10 at 05:22 PM |
thanks mate! where can i buy a couple of pairs? they will do nicely.
Johneturbo
| posted on 18/11/10 at 05:46 PM |
I bought mine from sabelt uk, when i also got my harnesses
try
HERE
daniel mason
| posted on 18/11/10 at 06:04 PM |
thanks mate. very helpful!
