Mave
posted on 24/6/04 at 05:43 PM |
Fiat Barchetta instruments: possible??
While browsing E-bay, I came across a picture of the interior of a Fiat Barchetta. I definately like the instruments, all grouped around the steering
column, with the warninglights fully integrated. Could I use these in my Indy somehow?!?!?
What kind of trouble could I expect?
Oh, the link for the picture is:
http://home.arcor.de/peter.florack/IMG_0562.JPG
andyps
| posted on 24/6/04 at 06:05 PM |
At a guess, the main issue would be speedo calibration. Otherwise, so long as you can connect everything up correctly i can't see any reason why
not.
Need to look for a set myself - I like them!
| posted on 24/6/04 at 06:09 PM |
Seeing the instruments through the steering wheel would be the only problem I could think of. It would be an easy look to copy using round dials. The
speedo must be the only one you have to be able to see easily so it would be obvious to place it first.
Mave
| posted on 24/6/04 at 06:53 PM |
Seeing them thru the steeringwheel might not be such an issue. By the looks of it, they are very closely grouped around the actual column, so as long
as I'm not going to use a 10" steeringwheel, it might work.
My concern is more hooking them up to the rest of the car, so they work properly.
PAUL FISHER
| posted on 24/6/04 at 11:55 PM |
intruments
only that they are in kph ,is that not a problem SVA?. Barchettas all LHD so I think they are all kph
Mave
| posted on 25/6/04 at 03:09 PM |
Yep, they're KPH, but since I live in Holland, that's good! However, I do believe the SVA (which I have to go through) requires MPH, but
maybe an added bicycle-computer would be sufficient? It might fall off during the trip back to Holland though.....
theconrodkid
| posted on 25/6/04 at 03:42 PM |
jap imports have mph numbers stuck on the glass,should be able to get some somewhere????
who cares who wins
pass the pork pies
andyps
| posted on 25/6/04 at 09:16 PM |
Pretty sure the barchettas sold in the UK will have mph speedos - especially if it is a legal requirement. Definitely all lhd though.
I noticed the local fiat dealer had one outside the other day so will go and have a look tomorrow if I get chance.
andyps
| posted on 26/6/04 at 09:22 PM |
Went to look today - the Barchetta I saw certainly had mph speedo. Nice motor.
