damdy-cash
posted on 14/1/11 at 04:10 PM |
Exhaust reducer/insert from 2,5 to 2,25
right, I've got a new silencer with 2,5" connection pipe and my primary is a 2,25... Length and everytinhg else is spot on, so I need to
get a insert that would cover the gap inbetween the two pipes.
Does anyone know where I could get something like that?
Many thanks for your advice and cheers Volker
hughpinder
posted on 14/1/11 at 04:29 PM |
I have no idea wher you can get one of these:
http://www.merlinmotorsport.co.uk/p10934/JETEX-STEPPED-SLEEVE-50.8/57/63.5-STAINLESS/product_info.html
Regards
Hugh
scutter
posted on 14/1/11 at 05:08 PM |
Or this
Exhaust Reducer Connector Adapter - Made to Measure on eBay (end time 22-Jan-11 07:48:58 GMT)
ATB Dan.
907
posted on 14/1/11 at 05:15 PM |
If I understand the problem correctly then you use a short piece of 2.5 pipe and cut a 10mm sliver out of it.
Squash in the vice to close the gap and you have a piece of 2.375 pipe that will slip in the can and over the primary.
No need to weld it. Your exhaust clamp will hold it in place.
HTH
Paul G
damdy-cash
posted on 14/1/11 at 07:33 PM |
Many thanks guys and spot on 907!!
I've already found a 2,5" tube for the job.
Many thanks and cheers Volker
