givemethebighammer
| posted on 4/7/04 at 02:08 PM |
SVA dash complete !!!
After several weeks of messing around I have finally finished and wired my SVA dash. Basically it's made from 5mm MDF, with 5mm thick camping
roll mat glued and stapled to it then finished with black vinyl material glued and stapled to the roll mat. Ended up buying a set of VDO gauges from
lowtension due to having problems finding senders and ways of getting an accurate reading from the speedo with the old triumph dolomite gauges I had
intended to use (however managed to sell them for a little more than I bought them for !!). I kept the triumph "cheese wedge" dash warning
light unit and modified it as SeaBass details on his site http://www.bass2dark.freeserve.co.uk/141003/141003.htm
So enough padding to sleep on, loom all covered and secure... enough for Mr SVA ? I sure hope so.
Then..... on goes the carbon dash.. layout the same as the photos just carbon......mmmmm
[Edited on 4/7/04 by givemethebighammer]
givemethebighammer
| posted on 4/7/04 at 02:09 PM |
more photos
barrie sharp
| posted on 4/7/04 at 03:12 PM |
that looks good !
mine was made just like that the only thing the sva man said was as long as you could not feel the wood on the edges its ok.
Barrie
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
SeaBass
| posted on 4/7/04 at 05:32 PM |
Jobs a good un...
subk2002
| posted on 4/7/04 at 09:52 PM |
So do need to have a padded dash for sva ??
givemethebighammer
| posted on 4/7/04 at 10:02 PM |
nope, but the bottom of the dash has to have a 19mm radius is it isn't.
Padded dash makes it easier to recess instruments etc and doesn't need as larger radius on the bottom (5mm I think).
I am going to change this one for the carbon one I am currently making after the SVA. (just waiting for the carbon sheet to arrive).
