bi22le
| posted on 18/3/11 at 11:24 PM |
Recommend me a switch!
Hi all,
Im at the point where I need to order an indicator switch and a main\high beam headlight switch. The current ones are old and look ugly. I would like
some toggle switches but they all seem too short or 'classic' looking. I use my car for track days and I want it looking functional. Also
easy to find when wearing gloves and probably cold!
So what ones do you lot have and what ones should I have?
Thanks in advance.
Good luck with the winter work, roll on the summer!
Biz
Please read my ring story:
adithorp
| posted on 19/3/11 at 10:32 AM |
I'm using toggle switches with rubber covers. Simple,discrete and easy to use with gloves.
For the lights I've used a Durite 3 position side and headlight switch (pt no 0-645-00) which is Off / side on / side and head on. It's
the only toggle switch I could find that had that configuration. Dip and main are wired through a change over relay, tiggered by an seperate on/off
toggle switch.
http://jpsc.org.uk/forum/
bi22le
| posted on 19/3/11 at 11:16 AM |
Yep I liked your idea and have gone down the same route. I never thought of the rubber covers for the toggle switches but as I am respraying the dash
black I think it would look nice with black switches. If I want to break up the black alittle I can easily take the rubber boots off.
Just went to Maplin a brough what I needed so thanks adithorp.
I have savage switches for lights on a flash beam. The other switch I need is just to switch between fixed low and high.
Seems like nobody else was out there to contribute so cheers again,
Biz
