sdh2903
| posted on 26/4/11 at 05:58 PM |
dash layout opinions
I know dash board layouts are all personal preference but am looking for some second opinions.
I am using one of these in my dash
  stack
It does tacho and also has a digital speedo and odo display along with selectable voltmeter, track timing and a few other bits and pieces. To go with
it ive got a few aux 52mm guages for oil px, water temp and a fuel guage.
I just cant decide whether I should have a seperate 80mm speedo to go along side it ?? I just cant get it out of my head that one 80mm gauge will look
a little unsymettrical? The one instrument covers iva requirements so its purely for appearance. My two very childish drawings below show what i mean
(my 9 year old has just been mocking me for my attempts!!)
2 x 80mm gauges:
  dash1
1 x 80mm gauge:
  dash2
by the way the strange dots are switches!!
Any thoughts?
franky
| posted on 26/4/11 at 06:22 PM |
You can put 2 temp/pressure channels in your stack display, you'd have to cycle through to them though.
Stack do a matching 80mm speedo, or SPA do one that will do some other bits too.
I like dash one as it looks balanced
sdh2903
| posted on 26/4/11 at 06:29 PM |
St500 doesnt have the additional sensor inputs like the St700 so it has to be separate gauges for temp/pressure.
I think thats the word i'm after balance, the 2 80mm i think do look a bit better, just trying to justify an extra 170 quid for something i dont
really 'need'
franky
| posted on 26/4/11 at 06:30 PM |
Also i'd get the seat in the position you're going to sit in, and your post IVA wheel and work out what you can actually see when
you're in it.
blakep82
| posted on 26/4/11 at 06:36 PM |
for IVA, you're not allowed to have a speedo that doesn't always show a speed.
so you couldn't use that stack tacho as a speedo, as it can show other info in that LCD display other than speed.
you have to have a purpose speedo in there, so 2 x 80mm (1 speedo, 1 tacho) is probably the best way
[Edited on 26/4/11 by blakep82]
________________________
sdh2903
| posted on 26/4/11 at 06:42 PM |
Your right, however the display is only changable if the button is installed to change it, for Iva this button may *ahem* fall off, Leaving the Mph
and odo display. However I am definitly leaning toward the 2 dials.
franky
| posted on 26/4/11 at 06:46 PM |
really 'need'
If that's what you want and you don't get it you'll always wish you had.
Well thats the way I thought about it as you're going to spend most of your time in the car looking at that one area, you might as well make it
suit you.
bi22le
| posted on 26/4/11 at 06:57 PM |
Personally I like the idea of one large gauge but not your layout. I think 1 large gauge would hint at being more purposeful use like track days.
I would maybe have the large 80mm central to driver view and one gauge either side. The third gauge could go top left of the buttons or else where.
Cant be bothered to edit your pic, but I think it would look better than the 2 gauge design.
HTH
Biz
Please read my ring story:
blakep82
| posted on 26/4/11 at 07:18 PM |
ah cool, but remember if it still changes between mph and odo, unless it shows both at the same time, it may not pass (as its possible to switch to
odo, showing no speed)
sdh2903
| posted on 26/4/11 at 07:41 PM |
Yes the odo and mph are on the same display.
Ive just seen this and really like the layout, just need to see what space/view i have now:
Miks15
| posted on 26/4/11 at 08:22 PM |
Thats the layout id go for! Looks good.
ShaunB
| posted on 27/4/11 at 07:35 AM |
I also like the idea of balance, so here's another variant. Replace 2 of your 52mm gauges with a single combined oil px/water temp to give you
52 - 80 - 52.
As others have said you do need to sit in the car with the steering wheel you are ultimately going to use in place and see how much you can see
through it. I my case I made a paper template and sitting in the seat used a pencil to draw an outline of the "shadow" of the steering
wheel and then laid my dash out how I wanted it. I actually placed a couple of switches in that shadow (high beam and horn) so they were under my
fingertips while driving.
Shaun.
The Black Flash
| posted on 27/4/11 at 07:50 PM |
I rather like asymmetrical layouts myself - as said above, it can look more purposeful. Either way, it's more important that you can see them,
than the layout looks nice IMO. If it works, it'll look right...I think
