rayward
| posted on 22/6/11 at 02:13 PM |
Best way to trim dash blank ?
should have my new dash blank today, and just wondered whats the best way to transfer the shape of the cuttle to the blank before cutting it ?
cheers
Ray
RoadkillUK
| posted on 22/6/11 at 03:14 PM |
I would suggest using card or thick paper and cut to size
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
jossey
| posted on 22/6/11 at 03:16 PM |
card 100%
if you have a look at my pictures... i made my own dash from card and then wood and fibre glass.
paper or thin card is near impossible to do.
getting the angle right is a pain but i found that the outside angle and corner was the same as the inside so i used the outside of the scuttle as a
guide then cut the card into two left side and right side then stuck together to get the width correct.
hope that makes sense.
good luck.
maybe we need a locost template which we can print out and use....
DJ
David Johnson
Macbeast
| posted on 22/6/11 at 04:13 PM |
Did mine with a piece of scrap hardboard.
