Author: Subject: Steering wheel spacer - what do we think?
Humbug
posted on 5/7/11 at 07:09 AM Reply With Quote
20mm STEERING WHEEL SPACER FITS MOMO OMP SPARCO WHEELS | eBay UK on ebay.
Looks neat and a reasonable price, but it looks like the bolts just go through the spacer using it like a massive 6 hole washer rather than bolting the wheel to the spacer and the spacer to the boss. Would this cause problems with twisting stress on the bolts?
daviep
posted on 5/7/11 at 07:21 AM Reply With Quote
The bolt shouldn't see any shearing forces if they are tight, it's the friction between the surfaces being clamped that transmits the load.
Davie
matt_gsxr
posted on 5/7/11 at 07:23 AM Reply With Quote
Based on the fact that this geometry is about the same as that of a bolt on Sierra Driveshaft I can't see it being a problem. The frictional forces between the mating surfaces should take all those loads.
russbost
posted on 5/7/11 at 07:52 AM Reply With Quote
We use something similar on the Furore. I had a report comissioned by Cardiff University re the strains on a steering column & the forces transmitted are actually very small, so I'm sure this would cause no worries.
Fred W B
posted on 5/7/11 at 08:23 AM Reply With Quote
I really don't see it being a problem. If you want a physical example to compare, race karts (that can need very high steering forces) use 3 off M6 bolts on a PCD that is probably 50 mm.
And anyway, as said above, the bolts should not take the torque load.
Fred W B
[Edited on 5/7/11 by Fred W B]
