Author: Subject: PVA Glue
posted on 26/8/11 at 02:09 PM Reply With Quote
PVA Glue
Does anyone know if this is suitable for gel-backed carpets to ali panels?
Cheers!
It's Evolution Baby!
tilly819
posted on 26/8/11 at 02:32 PM Reply With Quote
i would not have thought so, PVA tends to bond well to porus material and ali isnt very porus, i could be compleatly wrong however since i have never tryed it
tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
Mr Whippy
posted on 26/8/11 at 02:41 PM Reply With Quote
PVA won't dry, use contact adhesive
but do test some on a small sample of the carpet & gel to see it is compatible first
[Edited on 26/8/11 by Mr Whippy]
whitestu
posted on 26/8/11 at 03:01 PM Reply With Quote
My kids were using PVA to stick sea shells to paper the other day when they were making collages and it worked amazingly well!
It also dries clear so won't look a mess.
I would have thought it would work well on carpet to Ali. It is cheap enough to have a go on a cut off.
Stu
posted on 26/8/11 at 03:33 PM Reply With Quote
PVA won't form a good bond to metal.
As already suggested contact adhesive ----- Evostick.
You could also try a hot glue gun.
posted on 26/8/11 at 04:52 PM Reply With Quote
Thanks people!
Mark Allanson
posted on 26/8/11 at 05:27 PM Reply With Quote
Just a tip with contact adhesive on ally, give the ally a quick dusting with etch primer a few hours before spraying the adhesive, makes it stick sooo much better
Dick Axtell
posted on 6/9/11 at 03:59 PM Reply With Quote
Great - just what I wanted to find out. But which contact adhesive is best?
trextr7monkey
posted on 6/9/11 at 04:26 PM Reply With Quote
As above PVA needs the water to escape to dry so metal is a no no, re contact adhesives we have found the stuff from Wickes/ Screwfix to be just as good as the original evo stik. hth
Mike
posted on 6/9/11 at 04:54 PM Reply With Quote
I ended up using the Alpha stuff from Woolies. Not cheap at £24 a litre (VAT and delivery inclusive), but it works well!
