Author: Subject: JK Seat Height
T6 KFR
posted on 20/9/11 at 11:47 AM Reply With Quote
JK Seat Height
just recently joined this site , and have to say its full of great chat.
Im re-building a RH2B for hill climbs next year , and at present stripping as much weight of the already heavy frame of the car.
Ive just taken delivery of new JK seats and after sitting them in the car the are too low and embarrassing as it sounds cant see over the bonnet and the aeroscreen (im about 5,11). I need to increase the seat height and it appears the seat frames only increase the level 25mm from what ive read.
Can someone suggest alternatives : i did find subframes on a site last night but wanst sure how they would work in a kit car???
Kev
HowardB
posted on 20/9/11 at 12:02 PM Reply With Quote
How much height do you need to gain?
if it's an inch or two, I would be inclined to get some 2x2 or 2x3 timber and make a spacer, if it's more then perhaps some money might be required to get some ali formed.
Wood is cheap, and light
Howard
Daddylonglegs
posted on 20/9/11 at 12:06 PM Reply With Quote
What about something like Aluminium Box Tube 50mm x 40mm x 3mm Wallx1000mm Long | eBay?
rodgling
posted on 20/9/11 at 12:29 PM Reply With Quote
I used some steel tube as above to improve forward vision for IVA. Removed post-IVA as I can see fine without it.
Alternatively, use seat runners - this will give you a few inches plus you get adjustable seats.
watsonpj
posted on 20/9/11 at 01:04 PM Reply With Quote
I've used the 2" square alloy tube approach else at 5'5" sitting in my fury was a bit Little britain.
dwlb
dwlb
Pete
T6 KFR
posted on 20/9/11 at 02:48 PM Reply With Quote
I would be looking at gaining another 2" potentially (wouldn't we all )
I didn't consider square plate or wood as I was concerned on stress if I needed to stop quickly...maybe that is the only option other than purpose built subframes.
T6 KFR
posted on 4/12/11 at 11:48 AM Reply With Quote
embarrassingly I'm only getting round to fit the seats now, and realised jk composites didn't supply bolts for fitting.
I know a good few of you have these fitted already so I guess I'm looking for direction on bolt size?
cheers
kev
T6 KFR
posted on 8/1/12 at 04:17 PM Reply With Quote
anyone?
what bolts did you use for the jk seat fitment.
thanks
andy996tt
posted on 16/3/12 at 08:00 AM Reply With Quote
I got my seats from JK with the custom thread inserts embedded inside them. These would fit M8 bolts
