Author: Subject: inertia reel seatbelts
skinny
posted on 10/8/04 at 10:10 AM Reply With Quote
hi, i wanted some static seatbelts but am having trouble finding a pair so am looking at inertia reel belts.
does the mechanism always have to be mounted at the same orientation they were used in the original vehicle or will they work whatever?
also, what does the designation 500/15 and 500/30 mean?
thanks
if you don't fail, you aren't trying hard enough.
stephen_gusterson
posted on 10/8/04 at 11:17 AM Reply With Quote
they need to be mounted roughly vertically and straight or the centrifugal clutch wont work correctly....
atb
steve
DavidM
posted on 21/8/04 at 08:22 AM Reply With Quote
Both Stafford Vehicle Components and Europa supply a range of static seat belts. Europa have a wider range and also appear to be slightly cheaper like for like. They both have details on their websites. Let me know if you need contact details.
atb
wicket
posted on 28/8/04 at 08:37 PM Reply With Quote
500/15 & 500/30 are Securon part numbers, see here http://www.securon.co.uk/seatbelts_layouts.htm#up
