JeffJeffers
| posted on 7/12/11 at 08:21 PM |
seat belt mounting
Does it matter which way up the top hat washer go on the seat belt bolts?
mad-butcher
| posted on 7/12/11 at 08:34 PM |
Not sure, but all the seat belts I've seen come ready assembled with the bolt secured by a fibre washer
wicket
| posted on 7/12/11 at 11:06 PM |
The head (larger diameter) goes between the belt bracket and the chassis captive fixing.
adithorp
| posted on 7/12/11 at 11:19 PM |
Thats the usual way. The reason is to lft the belt buckle/bracket away from the mounting surface. Otherwise the belt would rub where it wraps through
the belt buckle/bracket.
http://jpsc.org.uk/forum/
austin man
| posted on 7/12/11 at 11:20 PM |
the belt should be able to swivel when fitted properley
JeffJeffers
| posted on 7/12/11 at 11:51 PM |
Do I need to get some fibre washers? And if so do you put them between the top hat washer and the chassis or washer and bolt?
wylliezx9r
| posted on 8/12/11 at 08:55 AM |
The fitting kit that came with my belts had no fibre washers. The belts ate very secure but still swivel.
George Best
wicket
| posted on 8/12/11 at 09:23 AM |
Some come with a wavy washer that goes between the head of the spacer and the belt bracket.
JeffJeffers
| posted on 8/12/11 at 10:16 PM |
I just want to make sure I get this right before I tighten all my seat belt bolts up.
It tightens up like in the picture I don't need to put a washer between the spacer and the bolt?
  seat belt bolt
Davegtst
| posted on 8/12/11 at 10:23 PM |
Do you actually need the mounts to swivel for the iva? I was planning on bolting them down without any top hat washers so they can't move.
Dusty
| posted on 11/12/11 at 01:28 AM |
Yes, the belt mount must swivel. This allows the loop of belt through the mount to lie along the bar in the mount with the tension spread equally
across the belt loop, whatever movement the wearer makes. Otherwise it may be possible for all the strain to be on one edge of the belt, tearing
progressively through it in the event of a crash.
mistergrumpy
| posted on 11/12/11 at 12:50 PM |
Mine don't swivel and passed SVA no issues. My belts never came with any top hats and looking at the picture a top hat would never fit like that
one throught the belt buckle hole.
I apologise in advance for going off topic but to save adding another thread and when the O/P's question is answered could someone possibly
measure the bolt hole diameter in the belt fixing buckle for me? This has been bugging me for around 3 years now with mine.
[Edited on 11/12/11 by mistergrumpy]
mistergrumpy
| posted on 28/12/11 at 05:36 PM |
Anyone? Can anyone measure the bolt hole diameter?
