Author: Subject: Fitting handbrake trim ring
scoobyis2cool
posted on 15/8/04 at 04:23 PM Reply With Quote
I have a bit of a problem with fitting my handbrake trim ring. It is held down by 6 bolts through the top tunnel cover, but there are lots of chassis rails in this area and some of the bolts will interfere. The car is an Indy, has anyone else had this problem and how have they got around it?
Pete
alister667
posted on 15/8/04 at 04:52 PM Reply With Quote
I bought a small plastic handbrake trim ring from Europa. Used 4 screws to hold it to the tranny tunnel. Works OK. There's probably pics on my website somewhere.
All the best
Ali
http://members.lycos.co.uk/alister667/
scoobyis2cool
posted on 15/8/04 at 04:55 PM Reply With Quote
It's the bolt at the front of the trim ring that is causing the problems, there is a chassis rail exactly where I need to bolt through
Pete
mangogrooveworkshop
posted on 15/8/04 at 05:22 PM Reply With Quote
Drill an tap it or place a rivinut there
locoboy
posted on 19/8/04 at 03:30 PM Reply With Quote
or as its not really a structural piece just bolt/screw it on with the holes that are ok to use, and glue the head of a matching bolt in the correct place on the unusable holes, looks ok from the outside and no one will be any the wiser
Locoboy
