Xy
posted on 25/8/04 at 06:54 PM |
Aluminium Sheets
I'm about to start making my dash panel and I'm trying to get hold of some aluminium sheets.
I live near Oxford so could anyone recommend a local (ish) supplier ???
I know that I need a 19mm lower radius for SVA, but what are the best ways to go about forming this with aluminium???
Any help would really be appreciated!!
Many thanks
Matthew
locoboy
| posted on 25/8/04 at 08:02 PM |
i have not done it myself but it would make sense to cut it over size for height then form the bottom of it around a suitable sided tube.
Locoboy
| posted on 25/8/04 at 09:41 PM |
Are you covering it?
If you cover it you can use the padding to form the radius. Polished alli dashes are a bad idea, they dazzle you.
Xy
| posted on 26/8/04 at 09:01 AM |
Yes, I'm planning to cover it with some form of vinyl.
The main problem I have is trying to find somewhere to buy the ally from........
Matthew
givemethebighammer
| posted on 26/8/04 at 09:48 PM |
from yell.co.uk
search for aluminium + oxford
Preform Engineering & Aluminium Co.Ltd Tel: 01295 250724
Thorpe Way, Banbury, Oxfordshire OX16 4SP
Classification: Aluminium Stockholders
could also try fabrication places or general metal stockholders ?
ps: ask for offcuts much cheaper, pay cash cheaper still (I've has some large (2m X 1.5m) size offcuts for next to nothing
[Edited on 26/8/04 by givemethebighammer]
Xy
| posted on 27/8/04 at 08:03 AM |
Cheers!
scutter
| posted on 1/9/04 at 10:33 PM |
Matthew , If it's just a dash panel there maybe some at work that i can find.
Can you let us know what size you need.
ATB Dan
[Edited on 1/9/04 by scutter]
stephen_gusterson
| posted on 1/9/04 at 10:57 PM |
I made the safe radius at the bottom out of wood.
get a suitable sized bit of wood, (in my case about 30mm thick and 40mm deep) and sand it with a power sander to a decent radius. then cover it with
sleeping bag roll underlay (sponge about 10mm thick holding it with double sided tape.
then, wrap the whole lot with the same pvc you are using for the dash. You can then mount the padded radiused 'bar' at the bottom of the
dash panel, which can have a simple 90 degree flange.
atb
steve
[Edited on 1/9/04 by stephen_gusterson]
Xy
| posted on 2/9/04 at 12:22 PM |
Dan
You have u2u.
