theduck
| posted on 16/5/12 at 03:14 PM |
Locost seat spacer/mount
I have a floor mount grp seat but because of where I need to mount it I need to lift the rear slightly, which will have the added benefit of improving
the driving position for me. I was in the garage last night having a planning night while I wait for buts to arrive and remembered a solution I had
seen to this type of problem before on another forum and subsequently orders two of these to modify for the purpose...
Will let you know how I get on!
[Edited on 16/5/12 by theduck]
HowardB
| posted on 16/5/12 at 03:54 PM |
surely there has to be a less costly way to get hold of engineering plastics?
Howard
loggyboy
Arent they hollow plastic though and likely to collpase with any major weight once drilled though?
If you have screw fixings in the base whats wrong with a load of penny washers?
Mistral Motorsport
theduck
| posted on 16/5/12 at 04:26 PM |
The ones i saw used before were solid, and you can pick these up very cheap, I paid £3.08 for two delivered to my door.
Penny washers would work but due to how much I need to lift the rear I wouldnt like to stack penny washers that high, and these being wider will
spread the load.
If it doesnt work, not much lost.
Worzey
| posted on 16/5/12 at 05:12 PM |
I used some rubber door stops.
Caterham R400
Fred W B
| posted on 16/5/12 at 06:31 PM |
Block of wood would work just as well. If it could be seen wrap it in black tape or paint it.
Fred W B
theduck
| posted on 18/5/12 at 10:24 AM |
So err... yeah the ones that turned up were hollow...
loggyboy
| posted on 18/5/12 at 10:44 AM |
You want one of these maybe, but being solid rubber will be quite heavy.
Ice Hockey Puck - Black | eBay
I was thinking of getting one as a jack top protector. Cut a small 30mm reccess in one face, fix the other to the jack and it should protect my
chassis when jacking off the frame.
[Edited on 18/5/12 by loggyboy]
Mistral Motorsport
