James
| posted on 17/5/12 at 05:45 PM |
Converting bolt-on harnesses to clip on
After my failure to come up with an elegant solution to this:
http://www.locostbuilders.co.uk/forum/2/viewthread.php?tid=170034
I'm investigating being able to move the harnesses between lower mounts by having them clip-on.
Is it possible to buy a 'convertor' to change the lower mounts on my belts to clip-on? If so, where? Can't find them at the usual
suspects.
I don't want to change belts (can't afford to!). I suppose I could look at buying the clips and then having them sewn to the belts lowers
instead of the bolt-ons... but this strikes me as going to be expensive to get sewn correctly.
James
- Muhammad Ali
mad-butcher
| posted on 17/5/12 at 06:57 PM |
seem to remember I think it was the corsa c had a chrome rail for a sliding belt mount on the outer mount, the rail bolted to the body and the fabric
loop of the belt just slid backwards and forwards on it
jacko
| posted on 17/5/12 at 07:35 PM |
I was just thinking the same as you my Wife has a corsa B and its as you have described
Jacko
Not Anumber
| posted on 21/5/12 at 02:46 PM |
Early Vauxhall coupes and all Ford Capris also had the sliding rail. I remmber it worked well and would justify having to make another anchorage
point.
