Xy
posted on 7/9/04 at 12:02 PM |
Steering Column Thread ?
Could anyone tell me what thread is used on the end of a Sierra steering column ??
After SVA, I'm planning to screw on a quick release hub (and then bolt through in position) so I need to find out the required thread
spec....
TIA
Matthew
[Edited on 7/9/04 by Xy]
Stuart Walker
posted on 7/9/04 at 02:39 PM |
sorry to go off topic, but are you doing this because a quick release boss isnt SVA friendly or for another reason?
Xy
posted on 7/9/04 at 03:18 PM |
I believe that the quick release mechanism isn't an SVA fail in itself, but using the original Sierra steering wheel makes life alot easier....
givemethebighammer
posted on 10/9/04 at 08:17 PM |
sure sierra column thread is M14 x 2.0.
Had to buy a replacement nut a while back Ford don't even stock them !!! Only went there because I wasn't sure if the nut was special in
any way. They said nope just a standard M14 nyloc. So local nut and bolt stockist sold me a couple for a quid.
Mark Allanson
posted on 10/9/04 at 09:17 PM |
Theiving bastards, I bought 10 for my trailing arms for £2.20!
Xy
posted on 11/9/04 at 12:26 PM |
Thanks for the info.
