Sloan85
posted on 13/12/12 at 10:38 PM |
Exactly what switches do I need?
Trying to work out exactly what switches I need. Im liking the look of the savage switches but with the list I have drafted up its going to be 8
switches/lights so is going to be quite expensive - therefore need to make sure I have got it right. This list is compiled from looking what switches
various other people have used and I was wondering if I need them all or can I loose some?
So far I have got...... (colour of LED shown too)
Latching switches
Side light - Green
Dipped headlight - Green
Main beam - Blue
Rear fog - Amber
Momentary switch
Horn - Red
Engine Start - Red
Warning light
indicator warning light - Green (operated by on-off-on rocker switch)
Brake warning light - Red (switch on master cylinder reservoir)
Is the anything I have missed or got completely wrong here? Any other advice from people with regards to choosing switches?
Cheers!!
omega 24 v6
posted on 14/12/12 at 06:23 AM |
Oil press warning light
alternator warning light.
Pretty sure that the rear fog needs to be red and not amber ( maybe wrong though)
Wipers switch
Hazard warning switch.
pekwah1
posted on 14/12/12 at 11:02 AM |
If you haven't already, your brake warning light also needs a test switch.
Most people use the handbrake for this.
So the brake reservoir and handbrake operate the same brake warning light
As far as i am aware, you also don't need any lights for the dipped beam as long as the switch is adequately labelled.
[Edited on 14/12/12 by pekwah1]
umgrybab
posted on 14/12/12 at 07:13 PM |
I also thought the dipped and main beam needed to be mutually exclusive, so when you turned on the main beam, it turned off the dipped beam. I may be
wrong but I'm pretty sure I saw that somewhere.
Sloan85
posted on 14/12/12 at 10:29 PM |
Ah, I missed Hazard switch.
For the oil pressure, I am using the GSXR clocks and I believe there is an oil warning on the screen?
Whats the alternator warning light for? Also I have seen people with a fan override switch. Is it recommended to have an override for the cooling
fan on a BEC?
(apologies, this is probably in the wrong section)
Cheers!
[Edited on 14/12/12 by Sloan85]
