jps
| posted on 15/6/13 at 12:31 PM |
bottom harness mounts
does this look like the way everyone else has done it?
pic in my archive, sorry but struggling to insert it direct to the post from my mobile...
thought I'd ask before welding!
Mr Whippy
| posted on 15/6/13 at 12:50 PM |
I would chamfer the plate where it to be welded and move the plate so the face is flush with the side of the tunnel, that way when you tighten the
seatbelt bolt it will not crush the tunnel paneling. I'd weld on both sides but then grind flush the weld on the compartment side (that's
why it needed chamfering) so the panel is not marked. Then weld on the captive nut for the seatbelt bolt, plate should be at least 3mm thick though
I'd use thicker.
The picture is very large and doesnot fit on the screen well, you need to reduce the resolution before posting
[Edited on 15/6/13 by Mr Whippy]
loggyboy
| posted on 15/6/13 at 01:15 PM |
For reference my striker ones look like this:
Mistral Motorsport
Mr Whippy
| posted on 15/6/13 at 01:55 PM |
That's a great prop catcher
blakep82
| posted on 15/6/13 at 02:04 PM |
I think a triangular shaped plate is definitely better. That way the hole is within the area supported by the welded sides.
With yours now, half of the hole is kinda unsupported (ok, its not that straight forward, but you know what I'm saying)
Hopefully you'll never need them, but if you do, you'd want them to be as good as possible
________________________
Smoking Frog
| posted on 15/6/13 at 02:20 PM |
Also check the position, mine are set further back (mk chassis).
Ben_Copeland
| posted on 15/6/13 at 03:24 PM |
Mine are further back too.. Haynes and Locost
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
jps
| posted on 15/6/13 at 03:51 PM |
Thanks for the responses - and especially the pics.
On the positioning - I've already got some mounts that are further back - the new ones are going in as a result of the feedback I got on this
thread: http://www.locostbuilders.co.uk/viewthread.php?tid=176283 which suggested I needed to have them further forward.
Last weekend I got in the seat with a harness draped across me - if I were to use the mounts that are further back the lower harness belts would be
going backwards at a 45 degree angle - the Willans fitting instructions say they should be going straight down vertically...
T66
| posted on 15/6/13 at 04:08 PM |
  New lower harness mounts
Ben_Copeland
| posted on 15/6/13 at 06:20 PM |
Personally i'd put them the other side of the vertical tube. Compromise.
Ben
Roadster
