AndyW
posted on 29/7/13 at 09:11 PM |
under the dash cover
Ok,
I have built a car, so why is such a simple task as making a cover for under the dash so flaming difficult. I spent hours on it and still can't
get it right.
Tried making a paper template, one from fabric, one from vinyl, one from pretty much everything I could get my hands on and nothing works. I need it
to be simple and just cover everything under the dash. AAAARRRRGGGGG
Will try again tomorrow before giving up completely.
Small rant over.
ReMan
posted on 29/7/13 at 09:16 PM |
Do you need to?
www.plusnine.co.uk
daveb666
posted on 29/7/13 at 09:33 PM |
I used foam board from Staples.
AndyW
posted on 29/7/13 at 09:50 PM |
quote: Originally posted by ReMan
Do you need to?
would like to. Make it look finished.
Sloan85
posted on 29/7/13 at 10:38 PM |
How much are you trying to cover under the dash? I made a couple the other week from thin aluminium that cover enough to protect all sharp edges but
are small and simple enough to install fairly easily. They tidy the area and will blend in nicely when I get them powdercoated.
They are only fixed at one end with the other end resting on the bottom lip of the dash. It's under a bit of tension so won't vibrate. The
only tricky bit was drilling and installing rivnuts upside down.
Build diary - Under dash panels
http://mkindygsxr.blogspot.co.uk
posted on 30/7/13 at 12:41 AM |
Did exactly the same myself, a good way of covering things up.
melly-g
posted on 30/7/13 at 12:35 PM |
I made some out of carpet,held in with self adhesive velcro. Works a treat!
