Chris_R
posted on 17/10/04 at 09:32 AM |
Girly sewing question.
Although my chassis isn't finished yet I decided to make a start on the seats. There is sound logic behind it. I've opted for the bench
style seats in the book as they seem to make efficient use of space without having a huge price tag attached.
Having bought some foam padding, wadding, vinyl and some 10mm ply, I went round to my Mam's and set up her sewing machine. I can only assume
that I'll also need to buy some specialist needles and thread as when I tried to sew two of the panels together I'd get half a dozen
stitches in and the thread would snap. This happened every time I tried without fail.
The girlfriend of a mate suggested plastic coated thread, but so far I've not been able to find a supplier. Does anyone have any comments,
suggestions, experience or know some suppliers that'll be able to help?
Cheers guys.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
stephen_gusterson
posted on 17/10/04 at 11:05 PM |
girlie answer. taught myself to sew with a cheapo machine
buy strong thread - i got a reel of M36 grade. The smaller the number the tougher the thread. I think tesco sell it as 'extra strong
thread'.
This stuff is so strong it will cut into your fingers before you can snap it.
for a needle - you need one thats for leather or denim. you can prob get one at a sewing shop, or buy discreetly on line, like I did!
Finally, make sure that the tensioner mechanism - the bit that pays the thread out at the top of the sewing arm above the needle - is set right. Too
low friction and the stitches will be loose, and too high and you will snap the thread.
atb
steve
[Edited on 17/10/04 by stephen_gusterson]
posted on 18/10/04 at 07:54 PM |
Tip from my mum who was pretty handy with a sewing machine, try sewing with a piece of greaseproof paper on top of the vinyl. Apparently this acts as
a lubricant and helps to stop the thread breaking. Also as already suggested check the tension. Hope this helps, Rusty.
ayoungman
posted on 19/10/04 at 09:43 AM |
sewing machines
Here are few tips that I've learn't whilst teaching boys how to use sewing machines.
First, keep your fingers away from the needle. They go through thumb nails beautifully !!
Most problems with machines come from incorrect thread tension.
Check the tension is even. Take hold of the top thread and hold the thread from the bobbin (thats the bit below the needle) now pull both threads
slowly. They should both pull at the same tension. If not, adjust knob on top and then the small screw on the bobbin.in is more tension, out is less
hope this helps.
DaveFJ
posted on 19/10/04 at 11:47 AM |
Hmmmm
Ayoungman.....
first the PINK chassis and now an apparent considerable knowledge of all things 'sewing'....
is Ayoungman perhaps a request rather than a name ?? ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif)
Dave
Chris_R
posted on 23/10/04 at 05:59 PM |
Cheers guys. Tougher needles and thread it is then. Will post some pics when I'm done.
stephen_gusterson
posted on 23/10/04 at 10:30 PM |
dont forget to get the tension right too!
atb
steve
Chris_R
posted on 24/10/04 at 08:18 AM |
Gonna sort that by borrowing a better sewing machine. All bases covered here.
stephen_gusterson
posted on 24/10/04 at 10:05 AM |
another simple thing.
when you start sewing you must hold the two thread ends away from you in gentle tension. I guess you know that, but if you dont it wont start the sew
properly.
I found it a lot eaier to sew than mig!
atb
steve
Chris_R
posted on 24/10/04 at 10:10 AM |
Hadn't thought of using the MIG. Might melt the vinyl though.
stephen_gusterson
posted on 26/10/04 at 02:07 PM |
ok
perhaps I should have worded it better
atb
steve
jack trolley
posted on 26/10/04 at 06:49 PM |
bench seat plans
There are plans & instructions for building a bench seat in:
The Car Builders' Manual
by Lionel Baxter
Chris_R
posted on 26/10/04 at 07:26 PM |
Now that's something I keep noticing on the self in Halfords but haven't bought yet. On the whole, what's the rest of the book like?
stephen_gusterson
posted on 26/10/04 at 11:00 PM |
i bought it a year or so back.
he claims to be a mate of ron champions.
its a bit like 'the book'. it details general stuff about kitcar building without any real in dept detail. similar to, and almost a
companion to rons book.....
its a decent light read.
atb
steve
posted on 27/10/04 at 07:22 AM |
It's a good book for anyone who wants a kit car but doesn't really know his way round a vehicle. It has a lot of general info, as Steve
says.
The bit on electrics is very good though - although I'm very comfortable working with electrics, I found his diagrams very useful. Mostly
because cars are wired in wierd ways!
The seat pattern is quite detailed.
You may not want to buy the book, but it is worth borrowing from the library.
rgds,
[Edited on 27/10/04 by David Jenkins]
Chris_R
posted on 27/10/04 at 05:05 PM |
Cheers guys. Think I'll pick up a copy on pay day.
