serieslandy
| posted on 26/2/14 at 08:23 PM |
Carbon Fibre Dash
Hi guys,
I'm after a carbon dash for my haynes. I made an mdf one but couldnt get a large enough radius on the bottom and I also lent on it and it broke.
So i want to replace it with something decent.
I like the look of the mk one but I'm not sure if it will fit or not.
What are the other options out there??
MK dash
Charlie_Zetec
| posted on 26/2/14 at 10:28 PM |
I've had one made (and got the mould) for my GTS which is similar in style to the MK one, but based on the McSorely +442 chassis - supposedly 4
inches wider at the scuttle than standard locost chassis.
Happy to take some measurements if you're interested?
serieslandy
| posted on 26/2/14 at 10:39 PM |
If you could that would be great. Also if you could get a pic?
Cheers, Steve
SteveWallace
| posted on 27/2/14 at 09:23 AM |
I made mine out of MDF and got the bottom radius by using 20mm radius plastic pipe, recessed into the MDF, from B&Q.
  dashboard edging
  painted dash blank
  finished dash 1
Autoflock Motorsport
| posted on 27/2/14 at 12:42 PM |
if you can make a plug of the shape you want making out of carbon then I can mould it and produce a composite replica
Kind regards
Raj
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=183445
