mazie
| posted on 15/6/14 at 08:12 AM |
Dash board materials
Morning all
Having to make to remake the dash on the fury. Im trying to find places to get some 3mm or 2mm carbon effect plastic sheet but have only found
something for £120 who is way yay to expensive for a dash. Any ideas or places people can recommend for something similar? Doesn't have to be
carbon look a likely but something that's pleasing to the eye :-)
40inches
| posted on 15/6/14 at 08:31 AM |
Depends how complex you want it to be, I built mine with layers of MDF and covered it with leather cloth and 3M 1080 carbon vinyl.
Slimy38
| posted on 15/6/14 at 08:32 AM |
Bog standard plastic sheet with a carbon fibre vinyl wrap?
Ugg10
| posted on 15/6/14 at 08:44 AM |
Mazie, the stuff that is in there at the moment was from fishers originally, they may be able to help, I did have some left over, wil check to see if
I still have it and it is in a fit state to use (probably a slim chance though). You could always use ally sheet and wrap it in film. You can even get
dark blue catbon fibre wrap to match the rest of the car -
http://offer.ebay.co.uk/ws/eBayISAPI.dll?ViewBidsLogin&item=281127498849&rt=nc&_trksid=p2047675.l2564
This is a bit cheaper, not sure about the width http://www.carbuildersolutions.com/uk/carbon-fibre-effect-abs-1350x600mm
Even cheaper - http://www.technologysupplies.co.uk/abs-carbon-fibre-effect-1372x660x2-0mm.html
More size choices here - http://www.plasticstockist.com/ABS-Sheet/Black-Carbon-Fibre-Effect-Abs-Sheet.aspx
Hope this helps.
[Edited on 15/6/14 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
big-vee-twin
| posted on 15/6/14 at 08:54 AM |
I have bought ABS carbon effect from playskool motorport for my boot lid.
My dash is made from a sheet of grp with the bottom radius covered with 3m di-noc, the di-noc is much nicer.
Did the tunnel aswell.
[img]
  clocks
[/img]
[img]
  Gear Lever fitted
[/img]
[Edited on 15/6/14 by big-vee-twin]
http://www.triangleltd.com
mazie
| posted on 15/6/14 at 10:09 AM |
Adrian thanks for the links, the last one is where I'd looked but typically I need a minimum length of 1400 and they stock 1372 or then 3metres.
Might go for di-noc over plain acrylic that I've already got stashed.
Does the 3m carbon fade or mark easily ??
40inches- nice interior, that looks the business!
40inches
| posted on 15/6/14 at 10:53 AM |
DiNoc is architectural and has been superseded by 1080 for automotive use. It has a slight gloss to it, I have used both and think the 1080 looks much
nicer. In my opinion You use an exterior trim treatment, 3M recommend McGuires (sp) Ultimate.
Slimy38
I think 3m give it a ten year life? But I don't think I've seen any that old. The stuff I have on my tintop is pretty resilient, the only
mark I've got on it was overrun when I was polishing the car. It's on the B pillar on the doors so it's in a pretty vulnerable
place.
trextr7monkey
| posted on 15/6/14 at 01:30 PM |
We deal with a firm called Technolology supplies and they do a sheet ofABS in carbon effect which is pretty good
Hth mike
