FuryRebuild
posted on 6/9/14 at 07:24 PM |
which is advice required - what is the correct way to mount my 6 point harnesses?
So, I have a set of 6 point harnesses (sparco) and they didn't come with mounting instructions.
I have read a lot of this great instruction pdf by
tillet but I'm not sure if using harness snap hooks is allowed for homologation, or if I should use
schroth bolt through brackets.
I've included pics below for both. I can either add mounting points behind me to the chassis, or weld a bar into my roll-hoop - I have options
here.
Your thoughts and advice please.
www.furyrebuild.co.uk
blakep82
posted on 6/9/14 at 07:37 PM |
For iva or race?
Snap hooks are fine all round. FIA approval is good for iva now.
Any worries about them coming unhooked, use a small split pin through the tiny hole and its all good
________________________
FuryRebuild
posted on 6/9/14 at 10:05 PM |
Hi Blake,
Race and track day. Car is well through SVA and is being rebuilt.
M
blakep82
posted on 6/9/14 at 10:24 PM |
They should be fine then! They'll have all the race approvals on them if they're sparco ones. Don't see it being a problem at all
