| posted on 30/10/15 at 02:58 PM |
Switchgear Legend Stickers
Any recommendations for switchgear legend stickers?
I've tried the Car Builder Solutions one's...
LINK
They're perfect size and they cover all bases, but they're the 'cut-out' style and I think they look naff once daylight hits
surface.
Has anyone found similarly styled, but laser-cut types?
It's Evolution Baby!
Irony
| posted on 31/10/15 at 08:08 AM |
Doubtful you'll get laser cut ones. I drew my own and cut them from silver finish luminous vinyl. Looks quite cool. If you had a metal dash
you could have them laser cut out of the metal and put lit plastic behind.
Matt21
| posted on 31/10/15 at 10:31 AM |
My dad has a machine that cuts vinyl.
Its like a printer, but has a blade instead of ink nozzles. They come out on a backing sheet so you peel off the paper from the sticky side, locate
and stick!
Very useful indeed but a bit of a pain to set up, especially with so many separate items to have to draw around on the pc otherwise I would have done
some for you.
If there's a good amount of people after them it'd be worth while.
theduck
| posted on 31/10/15 at 08:45 PM |
They'd certainly sell. I'd be interested in some.
Smoking Frog
| posted on 1/11/15 at 12:13 AM |
I used the same legend sticker on mine. I cut them out round with a small washer over the legend and scalpel. Although I should have made a proper
job and had them engraved as the switches are on a detachable piece of aluminium. May still do that.
| posted on 1/11/15 at 04:10 PM |
I'd be up for a set!
